After replacing my CCT...
Old Feb 14, 2011 | 08:28 AM
Jeff0044's Avatar
Default After replacing my CCT...
After I replaced my CCT with the A.P.E. manual tensioner the rattling noise went away but now I need to ask everyone that knows about these things.. it sounds like a chain is hitting the metal on the tensioner is this normal? I read a post that said that there is a normal "ping ping" noise is that what that is?
Old Mar 20, 2011 | 09:13 PM
R1der02's Avatar
I did the same thing and I dont have a sound like you described sorry bro cant help ya. It might not be tight enough thats my guess.
Old Mar 20, 2011 | 10:41 PM
iJapanesey's Avatar
Take it back off and reinstall it the right way.
Old Mar 21, 2011 | 07:21 AM
pittsm's Avatar
F4i CCT Swap - pictures/directions - BARF - Bay Area Riders Forum
here, this will help, make sure you followed these steps.
Old Mar 21, 2011 | 11:17 AM
brveagle's Avatar
You did not install it correctly. Did you remove your valve cover? It sounds like you may have it too loose still.
Old Mar 21, 2011 | 11:26 AM
itlnF4I's Avatar
thanks for that link pittsm, i just ordered my ape maual cct last night. cant wait to get that done
Old Mar 21, 2011 | 11:35 AM
Sick97SS's Avatar
As long as you tightened the 2 screws that hold it in (with the gasket), it's installed correctly. You shouldn't have to remove the valve cover or even the air box to install a cctl. just lift the gas tank. THAT'S IT.
TUNING it is another thing. There is a detailed STICKY thread on how to do this. As long as you are not deaf, it's easy to tune with the bike running. It may take a few times to get it right so be patient. After it's adjusted correctly there will be no noise at all. If there is ANY noise, rattle, squeal, etc, you need to adjust it again.
Old Mar 21, 2011 | 06:19 PM
DBEAU's Avatar
Where is this stickied thread on how to tune it?
Old Mar 22, 2011 | 09:44 AM
Sick97SS's Avatar
2nd thread down from the top of the F4i Page: https://cbrforum.com/forum/f4i-main-...-thread-78155/
My "how-to-adjust" post is on page 5
Old Mar 22, 2011 | 10:56 AM
nowensby's Avatar
https://cbrforum.com/forum/f4i-main-...e2/#post913637
For those who have changed the posts/page settings
