Replacing fuel pump....help
Old Sep 11, 2009 | 11:46 PM
C55's Avatar
C55
Default Replacing fuel pump....help
I need to replace the fuel pump on my 01 f4i. Anyone have any pics and/or suggestions? Also, when I try to remove my rear seat with the key it won't release the seat. Bike is stock and has not been ridden in a while. Battery has already been changed. Any help is appreciated. Thanks.
Old Sep 12, 2009 | 04:00 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
You can download a copy of the manual here: LINK. It'll have illustrations & step by step instruction. It should help you figure out the seat latch too.
Welcome to CBRF
Old Sep 13, 2009 | 10:46 AM
C55's Avatar
C55
Thanks for the link. I may be missing it but I could not find anything in there that deals with the rear seat not removing. For removing the rear cowl it simply tells you to use the key take the seat off. When I use the key nothing happens and the seat is still locked. Thanks for any help.
Old Sep 13, 2009 | 10:55 AM
C55's Avatar
C55
Also, the manual says to use new packing around the fuel pump and use new sealing washers between the fuel pump and hose and the fuel hose banjo and throttle body. Is this really necessary? I was going to try and get it done today but I bought the fuel pump from ebay and don't have that stuff new. Thanks again.
Old Sep 13, 2009 | 12:25 PM
Berto's Avatar
If you haven't got the seat off yet, the release cable may be stretched and not tight enough to release the catch. Try pushing down on the seat as you work the key. I'm assuming the key turns? If the key doesn't turn, you need to try another key.
You can reuse the brillo material around the pump, just be careful when removing and reinstalling. Ditto the banjo washer. It probably won't leak--mine has been through four tank removals and works fine. But if it does, you know what to do.
The large gasket between the plate and the tank should be replaced. It might not leak if re-used, but I've had them go both ways. If you must reuse it, smear it with a clear, silicone type sealer like Dow DC-4.
Follow the torque pattern and value *exactly.* If you over torque, you'll wish you didn't.
Good luck with it.
--Paul
Old Sep 13, 2009 | 12:35 PM
C55's Avatar
C55
Thanks Berto, I'm glad I got someone's opinion on that before I went at it. And yes, the key does turn. I'll give that a shot and let you know how it works out. Thanks again.
Old Sep 14, 2009 | 06:35 PM
C55's Avatar
C55
Ok, I got the fuel pump installed and it seems to operate normally (you can hear it prime). Now the bike won't start normally, I have to hold the throttle wide open for it to start. Then it seems to hesitate when I start to open the throttle. It will stay running (although not very well) as long as I give it gas. A few seconds after I stop, it stalls out.
The bike sat for quite a while and I thought the gas smelled funny and had a funny color to it when I changed the fuel pump. I got most of the old gas out and then put in some fresh stuff to see if that would solve the problem but it has not. Any advise? Thanks in advance.
Old Sep 14, 2009 | 08:47 PM
Berto's Avatar
I'd change the plugs. Check the air filter. Could be plugged injectors. You can can buy a cleaning solution to stick in the tank. You did change the fuel filter, I assume?
Old Sep 14, 2009 | 11:16 PM
F4ith's Avatar
If you have to start the bike with open throttle and it stalls if you don't give it gas, it sounds like it could be the idle speed. Check that throttle stop screw is in the right position. It's the little **** on the left side of the bike right above the engine cover/next to the 3 tubes. It should be set around 1,300 rpms. DON'T twist it too much! I had a similar problem with my F2 because I accidentally completely unscrewed the throttle stop.
Old Sep 15, 2009 | 05:08 PM
C55's Avatar
C55
Thanks guys, I'll give those things a try and see if it helps. I won't be able to get to it for a few days though because of work but I'll let you know. Thanks again.
mdunning
Jun 5, 2011 02:24 AM
Survivalism
Jun 2, 2011 11:44 PM
Turbulenz
Jul 31, 2010 07:45 AM
zblad
Dec 5, 2008 01:14 AM
