Replaced FPR & MAP and still getting 2 blinks error code
Old Aug 28, 2011 | 02:51 AM
kukku's Avatar
Default Replaced FPR & MAP and still getting 2 blinks error code
Hi All,
Haven’t been in here in a very long time; new job new house etc. = no time for anything else. Now that I can start enjoying myself again the bike is giving me some grief. I got the 2 blinks error code – MAP sensor issues. So, I start with checking the FPR (read my mechanic checks FPR) as I was smelling gas and found to be faulty. We replaced it with a new one, and serviced the bike (oil, filters, replaced coolant etc.), had to replace the spark plugs as one was found to be faulty. After a couple of outings, the MAP sensor problem returned. Ordered a new one and replaced, took the bike out a couple of times and all was fine with the exception of running slightly hotter than usual. It is 80 degrees here at night so not a biggie but will burp the system just in case. Took the bike out last night and when starting from cold it didn’t idle enough ..... and gave the MAP sensor fault again. I rode it till it warmed up, switched it off and on again; the fault disappears for the rest of the journey. What’s wrong with it guys?
Thanks a million for any help.
Chris
Old Aug 30, 2011 | 06:07 AM
kukku's Avatar
......... Anyone?
Old Aug 30, 2011 | 11:14 PM
F4iFern's Avatar
i would like to get information about this as well. my bike does the same thing and i am thinking about buying a new map Sensor for 127$. if buying a new one not going to make it work, i owuld like to find a way to fix it.
Old Sep 1, 2011 | 02:36 PM
F4iFern's Avatar
You figure anything out on your own about the problem with your bike Chris?
Old Sep 1, 2011 | 03:55 PM
lesiak392's Avatar
I have had a similar problem and started after I the restrictor removed (UK cat A licence). It was occasionally coming on but seemed to occur every ride after I put new downpipes on and thought they weren't tightened properly.
I racked my brains and always thought I had solved the problem but it ended up being ALL the MAP hoses were blocked with an 'oily sludge'. I cleaned this out and all is well. I would suggest before paying for a new one, check all the hoses if you can do this yourself obviously. If not, take it in to have the hoses checked as this is the usual problem.
Hope this helps.
Old Sep 1, 2011 | 04:20 PM
F4iFern's Avatar
alright thanks I just went to look at the Map sensor and i took it off and put it back on and started the bike. It turned on fine and the Fi light never turned on either did it take a while for the choke to start up. so i blew it with an air compressor to see if i could clean it out a bit so ill see how that ends up in the long run.
Old Sep 2, 2011 | 02:09 AM
kukku's Avatar
Not yet, but cleaning the MAP sensor hoses is on the cards. Will let you know how it turns out.
marac
May 29, 2018 05:04 PM
DJPlayer
Aug 10, 2013 11:37 AM
hon00cbr929
Jun 22, 2011 01:13 PM
929BEATSTI
May 1, 2011 04:49 PM
Sleek_929
Apr 16, 2008 03:24 AM
