Replaced chain/sprockets, now have knocking sound
Old Sep 21, 2010 | 11:37 PM
kowen1208's Avatar
Default Replaced chain/sprockets, now have knocking sound
I just replaced my -1/+2 setup with a stock one, and now I'm getting a knocking sound. I double checked the chain tension to see if that was it. The chain had relaxed a bit and had more play than at first, but I'm still getting the knocking after taking in the slack. Does the chain just need to be broken in or something?
Old Sep 22, 2010 | 12:43 AM
bleheny's Avatar
That is not normal... I am assuming you replaced everything with new. If not, the chain and/or sprocket(s) could be bad.
Did you:
Grease the axle before reinstalling it?
Properly lube the chain?
Install the master link correctly?
Clean the output shaft and counter sprocket housing before installing new?
Torque everything to spec?
The only things I can think of at the moment...
Old Sep 22, 2010 | 12:42 PM
gotcbr's Avatar
In addition to the above recommendations...
Is your rear wheel aligned properly in the swingarm?
Old Sep 22, 2010 | 05:40 PM
kilgoretrout's Avatar
Administrator - Retired
Yep, and also is your front sprocket definitely on correctly?
Old Sep 24, 2010 | 05:07 AM
DonnyBrago's Avatar
If you installed the chain yourself, I'd bet that you have overtorqued or incorrectly used the chain tool when installing the master link causing a stiff link. Get the rear wheel off the ground, find exactly where the noise is coming from and see if it happens at certain parts of the chain, certain parts of the sprocket etc to identify it.
Make sure you also torque the rear sprocket down in a star formation a few extra Nm at a time until you get them all down fully.
ROOKIE 09
May 7, 2011 05:02 PM
compster
Jul 23, 2010 05:50 PM
Unknown
Jul 20, 2010 10:16 PM
jv1964
Mar 31, 2010 08:23 PM
cheech80
Apr 24, 2009 09:19 AM
