Removing the Axle Nut
Old Mar 31, 2008 | 08:49 AM
bra1ndead's Avatar
Default Removing the Axle Nut
I got a new license plate bracket that attaches itself to the rear axle. To install it, I need to remove the axle nut. From what I understood in the service manual, the axle nut on 06 f4i is on the right side (when you are sitting on the bike) and the bolt is 18mm. However, when I tried to use my 18mm socket, damn thing wont fit. Neither does the 19mm socket. Anyone got any ideas as to which socket size I should get (because now I will have to go out and buy one).
Also, if I remove the axle nut, will the tire come off? The bike is sitting on a rear stand with the tire lifted up.
Old Mar 31, 2008 | 08:52 AM
muckdawg24's Avatar
Default RE: Removing the Axle Nut
27mm socket for the rear axle.
Old Mar 31, 2008 | 09:11 AM
ampfp's Avatar
just removing the nut wont take the wheel off
which is why probably the plate is to be installed on the nut side of it
remember to torque it back to the right spec using a torque wrench
Old Mar 31, 2008 | 10:28 AM
bra1ndead's Avatar
But I wanted to install it on the left side (the non nut side). I wanted the bracket to also act as a chain guard. I would basically have to remove the bolt on the left side. Will the tire come out then?
Old Mar 31, 2008 | 10:55 AM
krash's Avatar
yes, the tire will come out with out the axle. slide a brick or something under it so it stays close to being lined up when you remove the axle.
Old Mar 31, 2008 | 12:01 PM
SReeD08's Avatar
i have the same bracket on my 02 f4i. also acts as a nice chain guard. go to this post for pics, go to rear pic of bike.
https://cbrforum.com/m_521678/mpage_.../tm.htm#521713
lowcel
Jan 12, 2014 07:47 AM
Junior2552
Oct 16, 2009 08:50 AM
Hurricane rider
Oct 21, 2008 12:40 PM
jay arr
Nov 16, 2006 11:55 AM
jay arr
Nov 15, 2006 06:30 PM
