removing lock washer from axle locknut
RE: removing lock washer from axle locknut
I was mistaken. The nut on the rear axle has a little metal 2 pronged washer looking thing, I thought it was some kind of a lock ring because I had a similar looking nut chew up the threads on the countershaft of my last bike from just backing the nut off, but apparently that wasn't what caused it.
No, not the chain tensioner. I'm not as dumb as I sound, at least in this instance. If you look closely at the axle nut, you'll see what I'm talking about. Its a tiny little thing on the outside of the nut, but recessed from the outermost little ridge of said nut, and it just puts some tension on the axle threads to keep the nut from backing out. No matter how hard I try I can't come up with words to describe it, but it doesn't matter anyway because it doesn't change the removal of the nut process.
And in RE: to how can a bike go six years on stock tires? I thought they were supposed to have a cord-treaded center strip....
No, I got the bike last month with only 3200 miles. I've now nearly doubled that in less than a month. I don't know why or how anyone could buy a new bike and ride it 500 miles a YEAR
they can and often do because most people buy sportbikes to pose in the summertime and only ride to starbucks.
if you had a motorcycle psychologist interview the bikes...the prof will tell you that many sportbikes tell him/her that they are unhappy and bored...sort of like how people buy dogs and just leave them at home...
they want to be out...roaming, leaning, cornering, blah blah blah...so if that's the case...most bikes will be on prozac.
ORIGINAL: jay arr
but i make up for it with my F4i and SV on the track
