Axle nut hole doesn't line up with axle hole.
I just torqued the axle nut on my 600RR and noticed that the hole in the nut doesn't match up with the hole in the axle. Any suggestions on what to do? Is the only option drilling a new hole in the axle?
How do you wire it when you can't get the wire through the hole?
Is everything lined up right? Make sure the axle is seated on the other side.
Wire went through the hole at one time....
I wired mine around the adjuster.
I'm a moron. Doh.
I would drill again though, I don't think you're close enough to the original hole to have it be an issue with torquing/weakening...
