rear turn signal wiring.
RE: rear turn signal wiring.
You will have two that are the same color, but one has a stripe. The common/ground wire us normally green. Leave it connected and cut one of the other colors. Then test the lights to see which one still works. Or, get high tech on me and break out the multi meter or test light. Either way, you'll know the answer. And if I remember, the striped wire is the turn signals.
