Turn Signal Wiring
Put diodes in the two power wires coming from the bike allowing current to flow towards the one power wire on the signal and connect your ground as usual...OR... connect one or the other power wire (I recommend the signal wire) and the groun. The wires can be found in a downloadable manual in a link at the top of the general tech section! Hope this helped. PM me or do a search if you need more info
i feel like this picture should be a sticky for the amount of times ive posted it..lol
So all you need is your light blue and a green for the right, and your orange and green for the left.
If they are LED's make sure your ground is where it should be or they arent going to work at all, but you wont do damage hooking them up backwards
