rear pre-load stuck
Old Sep 29, 2006 | 11:52 PM
niskyne's Avatar
Default rear pre-load stuck
I've had my F4i for about 6 days now, and today I decided to try different settings for the pre-load. It was on 6, and with some struggle I brought it down to 4. I can't get it down to 3, because it is somehow stuck. I sprayed some WD40 to try to lube it up a little, but it still wouldn't budge. I also tried to use some more leverage by making the spanner+extension longer, but still no luck. Also, on one of the attempts, I pulled on it so hard that the bike tipped over on me, but luckily I caught it before it hit the ground. I also bent the spanner wrench sideways on another one of the attempts.
Any suggestions???
Thanks!
Old Sep 29, 2006 | 11:55 PM
ninetyfivehp's Avatar
Default RE: rear pre-load stuck
at least you got a tool kit. american honda fooked the 06' buyers
Old Sep 30, 2006 | 05:24 AM
dwhite645's Avatar
Are you sure you're on setting #3 and not already on #1? Because it shouldn't be that hard to move it. There's an indicator mark, one on each side, that should align with the number. Just checking because when I first started messing with mine I wasn't sure what was what.
Old Sep 30, 2006 | 05:29 AM
dwhite645's Avatar
It's the blue arrow. There should be an indented mark below the adjustment ring, as I discovered later.
[IMG]local://upfiles/4409/7E95E78F7ED84F3DB0185340A0091C24.jpg[/IMG]
Old Sep 30, 2006 | 11:40 AM
niskyne's Avatar
So the little line inside of the square "window" is where the preload is at?? I thought it was the notch at the top of the whole assembly facing up. So if that's the case, my preload is at 7 right now. But it seems a lot softer than before?
Thanks!
[IMG]local://upfiles/11142/945F77C754CE46E0973AC0A9780C8B2C.jpg[/IMG]
Old Sep 30, 2006 | 02:33 PM
FastCRX's Avatar
you and me both brother. I went to my dealer because i thought i got mine stuck too. Then he showed me the window and I told him I thought it was the top marker. He said its a common mistake
Old Sep 30, 2006 | 03:10 PM
voodoochyl's Avatar
Retired Moderator
I'm glad this thread was started because I would have thought the marker was straight up, as well. I do have to get a spanner wrench first, though. Thank you Honda, I didn't spend enough money with you yet, and I would like to purchase my own tool kit...hello Ebay.
Old Sep 30, 2006 | 05:53 PM
traitorhound's Avatar
man i adjusted mine today. .what a pita. . i had to use an old lacrosse stick shaft to get more leverage and it cracked the aluminum pipe. . .meh. . .but it worked and im all good now
Old Sep 30, 2006 | 07:04 PM
dwhite645's Avatar
Yeah, there's a window on each side and also an index mark. They should both show 4, or 5 matching or whatever on each side.
Old Oct 1, 2006 | 02:10 AM
jorge13's Avatar
what´s suppose is the medium better mark ?
Minor Miss Steak
Mar 29, 2013 06:14 PM
carsik
Mar 31, 2012 07:57 AM
[w]
Aug 5, 2008 11:08 AM
hawkgt
Jun 17, 2008 09:37 PM
Riding Red
Aug 26, 2006 02:21 PM
