Rear brake pads wear looks strange
Old Jun 12, 2018 | 08:54 PM
S1l3nced's Avatar
Default Rear brake pads wear looks strange
Hi all, first post here! Newbie mechanic and new rider too! Just removing the wheels to change the tires out when i noticed the brake pads seemed to be worn at a strange angle... also the rear rotor looks to be a bit off? I used a caliper to see the diff and it looks warped? Any idea what could cause this?? Any helps appreciated!
Old Jun 13, 2018 | 03:37 PM
S1l3nced's Avatar
Just to update... I've been informed it could be due to bad calipers? I'm thinking of just replacing rotors/pads/calipers... but before I go and do this job, I was hoping someone could shed some light into this and possibly let me know if there's anything I can do to rule out anything else as the cause?
Old Jun 13, 2018 | 04:02 PM
74demon's Avatar
Your pads show wear of a guide pin not sliding freely through the pad.
Old Jun 13, 2018 | 04:53 PM
S1l3nced's Avatar
Thanks for the reply! I did notice this weird bracket thing fall out as I moved the caliper away from the rotor. It looks like a black square thing.. possibly a rentention clip... could this be what you're talking about? I will take more pics when I get home and look up how to set this guide pin... By the way... in case the part I mentioned is NOT the guide pin... do you know where abouts I would find this? again I'm a huge noob and am still trying to figure this all out! Thanks again demon.
Old Jun 13, 2018 | 05:39 PM
74demon's Avatar
The pads should sit in a groove on the bracket with a metal piece of hardware. The pin is that rod that goes through the holes on the pad. Make sure that the pad slides easily on the pin and bracket. A little brake lube to help them slide is a good idea.
Old Jun 14, 2018 | 10:13 PM
S1l3nced's Avatar
Thank you. I'll give this a shot and reply back to this thread.
Old Jun 22, 2018 | 06:03 PM
S1l3nced's Avatar
We can close this if you guys want. I believe the rear is fine for now.
pookguy88
Jul 12, 2012 09:08 PM
phil k
Mar 24, 2011 12:13 PM
Krux
May 20, 2010 10:32 AM
EHonda
Apr 26, 2008 12:10 AM
BlindLOKI
May 4, 2006 01:41 AM
