Rear brake pads rubbing against rotors?
Do you?
You can see and check your rear pads by looking at the back of the caliper. Look and see if there is any meat left on the pads.
when in doubt take off the caliper and inspect. its one bolt.
FYI most rear pads never need replacing, like, ever.
...unless you have crazy high miles or abuse the rear brake.
Replace as necessary.
A little rubbing sound from the brake pads on the rotor is normal. You can hear it, but should not be able to feel it. If there rubbing to the point of dragging and binding, that's not normal. Take off the caliper and inspect. Make sure the little metal holders and hardware didn't get bumped and are hitting the rotor.
