replacing rear brake pads???help
so i got a new rotor(driven sport series) and new rear brake pads(galfer 1054 semi metallic). i thought this would be a breaze. i can get the pads in right but the rotor will not fit in between the pads not because of the brake piston out but because of the bracket that holds the caliper. should i be taking the caliper off the bracket to install these pads. rotor is 4mm thick just like the oem one i believe. please respond fast i need it by friday
Wish I could remember what I did last fall. I put a new set of EBC pads on the back, and I recall thinking at first, "Huh, that's weird. I wonder why I can't get the disc back in..." Then I recall having a realization, doing some fairly simple thing, and Bob's your uncle. Quite what that simple thing was is the question, though. It seems as though I simply dropped the rear wheel and slid it back up into position...?
