Rattle
Old Jun 21, 2017 | 09:17 AM
lifeboatman3's Avatar
Default Rattle
Hi I have just bought a 2002 f4i and its only done 5000 miles. On reving the engine as I back the throttle off I can hear a slight rattle from the top front of the engine. It sounds like something loose but before I start taking fairings off etc I just wondered if this was normal. Someone said it could be the hydraulic lifter need adjusting? Not sure thats correct on a bike with so little milage?
Thanks
Old Jun 21, 2017 | 09:36 AM
CaBaRet's Avatar
Hi, not sure what a hydraulic lifter is on your bike, but it could be the Cam Chain Tensioner, don't think it would need a valve clearance check with only 5000 miles on the clock, just check if its an automatic CCT or a manual one
Old Jun 21, 2017 | 02:37 PM
Thanks. How will I find out if it's automatic tensioner?
Old Jun 21, 2017 | 03:11 PM
CaBaRet's Avatar
Hi , a manual one looks like this
BP 1999-2006 Honda CBR 600 F4 F4i Blue Manual Cam Chain Adjuster Tensioner | eBay
and an automatic one looks like this
GENUINE HONDA CAM CHAIN TENSIONER LIFTER 1999-2006 CBR600F4 F4i (REVISED)
Old Jun 21, 2017 | 03:23 PM
OK thanks for that will have a look tomorrow. Just you tubed and mine foesnt sound as bad as the ones on there. It's just a rattle in the last power down from 3000 - 1500rpm. Could it be because the bike has only done 400 miles in the past 2 years. Might just need a good run?
Old Jun 21, 2017 | 06:02 PM
boredandstroked's Avatar
There are no hydraulic lifters on the bike. A rattle as you describe would not be the CCTL either. Its either valve clearance or normal enough none of us notice it to worry about.
jdh30292
Nov 27, 2011 07:30 PM
Jason01F4I
Jul 23, 2008 09:32 PM
EsteRollo650
Jan 15, 2008 06:49 PM
Phone Guy
Apr 6, 2006 04:04 PM
wheeliemonster
Oct 6, 2005 10:52 PM
