Question about oil level
Old Sep 25, 2006 | 11:06 PM
zero's Avatar
Default Question about oil level
I just changed my oil and have some question.
There are two lines on oil level window on right side of the oil pan. I though it need to be fill up to the top line when it is sitting stright like on stand and bottom when it is sitting on kick stand with some angle. Is this right? or it is just minmum and maximum oil level.
thanks,
Old Sep 25, 2006 | 11:10 PM
dwhite645's Avatar
Default RE: Question about oil level
That's the min/max line. Bike has to be sitting level and vertical.
Old Sep 25, 2006 | 11:53 PM
Blackdog F4i's Avatar
Another good reason to get a rear stand. Or just get a buddy to hold the bike upright when you fill it.
BTW, an owners manual is a good thing and answers questions like this and more.
Old Sep 26, 2006 | 01:15 AM
Pugetpower's Avatar
dwhites right. Two lines are the Min/Max lines. Fill to the top line. I drain the oil, change the filter, put the plug back in, fill about 3 1/2 qts of oil. Start the engine till the red light goes out, stop engine, tilt the bike to upright and check level (with a little flashlight between my teeth). Add if needed. I probably overfill by a 1/4 qt many times. Engine dont care.
DMACK
Apr 13, 2020 04:16 PM
Cahal
May 23, 2012 10:50 AM
HellrazerinDC
May 3, 2012 08:51 PM
wheelie_chris
Jan 10, 2008 02:08 AM
lang1864
Apr 11, 2006 09:23 PM
