Question about gas tank banjo bolt washers
Old Jul 28, 2012 | 03:32 PM
ryanCBRf4i's Avatar
Default Question about gas tank banjo bolt washers
I took off my gas tank and removed the large banjo bolt from under the tank and it came along with 2 small washers that were on either side of the bolt. They aren't looking as good as they used to so I phoned up a local parts store and ordered some more. But the service rep said there are actually 4 of them. 3 of them are 12mm and one is another size that I can't remember. What is he talking about?
I'm also looking at the service manual and it only shows two of them. I clarified with him that this is a 2003 CBR F4i and he made sure he had the right washers.
I circled the two washers that go on either side of the fuel line and banjo bolt. Are there supposed to be more washers or should I phone the store back and tell him he's got the wrong parts and that there are only two of them?
https://i.imgur.com/OEogr.jpg
Old Jul 28, 2012 | 07:34 PM
julss's Avatar
There should only be two washers on the end that connect to the fuel pump. The guy you talked to was confused. I'm not sure what size the washers are though.
Old Jul 28, 2012 | 07:49 PM
ryanCBRf4i's Avatar
I even called back and confirmed the location of the banjo bolt and the year/model and he said there are 2 washers that go on either side of the fuel line and 2 more washers on either side of the bolt. I don't know how we're getting 4 here but I guess I'll find out when the parts arrive on Tuesday. The washers I have now will still work but they can only be sanded down so many times before they need to be changed. Now would be a good time to change them since most of upper end of the bike is in pieces.
PossibleOne
F4i - Wanted
Dec 23, 2013 07:52 PM
sodahyogesh
F2 Tech
Mar 21, 2013 12:08 PM
__Z__
Apr 25, 2011 07:39 AM
brandonf2
Oct 6, 2010 12:52 PM
Glocker23
Sep 10, 2008 08:14 PM
