question about cctl.
Old Sep 8, 2006 | 11:18 AM
Jon Boy's Avatar
Default question about cctl.
I noticed that there are some end numbers that are different at the end of the part number of these oem parts. How do I find out which one I need. There is like J22's, J23's. Is that like the different motors code or something? Got around 12,000 miles on my 2001 and have a rattle around 4000-5000. Think I need to replace my cctl.
Old Sep 8, 2006 | 11:35 AM
Blackdog F4i's Avatar
Default RE: question about cctl.
The later number is the "revised" part that really wasn't "revised".
They will both rattle after a couple thousand miles.
You will need to either take yours out and flare the pin or buy a APE manual CCT. My vote goes to the APE because there is no way you can have problems with the CCT later.
Old Sep 8, 2006 | 12:17 PM
Jon Boy's Avatar
I thought about the APE but I was concerned about getting it sdjusted properly. But the more I think about it, I think that would be the best route to go.
Old Sep 8, 2006 | 12:19 PM
Tahoe SC's Avatar
ORIGINAL: Blackdog F4i
that's right mang...the APE cctl won't start making noise and stuff like stocker, but if you adjust it wrong...your engine will let you know...in a big way...BLING BLING! so make sure you do it right!
don't forget to get the end washer that goes at the rear of the stock cctl and a new gasket for either APE or stocker.
as far as j22 or j23, even if you order a j22, you'll get a j23 because there's no more j22s around...and if you end up with a 22, you better be getting an awesome deal off it! like free!
Old Sep 8, 2006 | 12:34 PM
Jon Boy's Avatar
Thanks guys for the replies. I think that I will do the APE. This is my first crotch rocket and I want to take her to Deal's Gap. Want to make sure she is all in check.
Old Sep 8, 2006 | 12:39 PM
ninetyfivehp's Avatar
i don't know if the j23's are better, but they definitely look different than the j22's
dgk600f4i
Jul 6, 2012 11:37 PM
pookguy88
Jun 25, 2012 08:04 PM
MitchA
Jul 23, 2010 04:51 PM
boredandstroked
Sep 20, 2009 09:47 PM
aref4i
Apr 25, 2008 05:16 PM
