question about cctl.
I noticed that there are some end numbers that are different at the end of the part number of these oem parts. How do I find out which one I need. There is like J22's, J23's. Is that like the different motors code or something? Got around 12,000 miles on my 2001 and have a rattle around 4000-5000. Think I need to replace my cctl.
RE: question about cctl.
The later number is the "revised" part that really wasn't "revised".
They will both rattle after a couple thousand miles.
You will need to either take yours out and flare the pin or buy a APE manual CCT. My vote goes to the APE because there is no way you can have problems with the CCT later.
ORIGINAL: Blackdog F4i
don't forget to get the end washer that goes at the rear of the stock cctl and a new gasket for either APE or stocker.
as far as j22 or j23, even if you order a j22, you'll get a j23 because there's no more j22s around...and if you end up with a 22, you better be getting an awesome deal off it! like free!
