pulling in clutch noise goes away
after warming up the bike, when u pull the clutch in, the noise goes away and when u let go again (still in N) the noise is back. its not annoying or anything just wondering why? or if something is going out. THANKS.
The clutch assembly makes some (keyword "some") noise when in Neutral and there's no pressure on it. when you pull the clutch, you apply pressure, and the noise goes away.
Perfectly normal on any manual transmission as long as the sounds are minimal.
