Problem After Changing Oil
Old May 18, 2007 | 08:43 PM
Morta's Avatar
Default Problem After Changing Oil
Well I just changed out the Oil & Filter on my 01 F4i and I'm having a little problem. I started it and let it run for a couple of minutes. The first minute everything seems fine... the High Idle is on and warming the engine up... However at about 2 minutes the RPMs start to go up (from about 2000 to 3000) and smoke is coming from the front end of the bike... I thought that the smoke may have been coming from some oil that I may have accidentally spilled on to the headers but I think I cleaned most of it up and am still having the problem. Has anyone else experienced something like this???
Old May 18, 2007 | 08:50 PM
fishfryer527's Avatar
Default RE: Problem After Changing Oil
The revs are puzzling, not sure if an overfill/underfill will affect the idle. Oil on the header will smoke no matter how much you wipe.
Old May 18, 2007 | 08:56 PM
Stephens's Avatar
I know what you did. I probably put in 4 quarts. The F4i needs only 3.5 quarts. If you overfill it, you will burn it out the pipe. Not good. Drain it out, and re-fill to 3.5 quarts.
Old May 18, 2007 | 09:06 PM
Morta's Avatar
Ok I will drain the oil out once the bike cools down some... about the Oil on the headers smoking... Is that just something I have to deal with until it goes away???
Old May 18, 2007 | 10:54 PM
Stephens's Avatar
You shouldn't have gotten that much on it, it will burn off. Nothing to worry about.
Old May 18, 2007 | 11:32 PM
95camaro01f4i's Avatar
i got the idea on here from another member but i wrape tinfoil around my headers when i change the oil
Old May 18, 2007 | 11:35 PM
Stephens's Avatar
Tin foil? If you are careful, you shouldn't get much if any oil on the headers when taking off the filter. But if that works, cool.
prowheelie92
Jun 3, 2010 11:22 PM
dewthedoo05
Sep 4, 2007 09:32 PM
canman
Dec 16, 2006 07:43 PM
tangelo
Nov 23, 2005 07:34 PM
WhiteTailCBR
Jun 13, 2005 04:11 PM
