Preload sag without the included wrench
Old Jun 23, 2011 | 11:30 PM
backyardmechanic's Avatar
Default Preload sag without the included wrench
Is there a way to adjust the preload on the rear shock without having the wrench made for the specific purpose? i have the 06 F4i and it did not come with one. I need to adjust the preload because i have been riding 2 up alot and im running 2in slack in the chain to get the tension correct with stock preload. I also want to adjust is more to suit me more(6'2" 200lbs) on the everyday commute. I would appreciate any advice guys. Thanks in advance
Old Jun 24, 2011 | 02:34 AM
madman's Avatar
You're going to need a spanner wrench of some sort. Out of desperation I used a pipe wrench once although definitely expect to beat up the metal collar pretty good if you decide to do that. The other day I was fortunate enough to find an old spanner/adjustable wrench type deal in an old toolbox for plumbing.
Anyway aside from finding/borrowing/buying a tool you could always remove the shock.
Old Jun 24, 2011 | 04:23 AM
DanishF3's Avatar
Ebay is your friend
Old Jun 24, 2011 | 07:50 AM
stingray's Avatar
yep, get a spanner wrench on ebay. for your weight you'll want to try preload setting 5 and bump it up to 6 when riding 2-up.
Old Jun 24, 2011 | 11:15 AM
boredandstroked's Avatar
Or use a hammer and punch [or screwdriver you don't like anymore] like most people.
Damo77
May 22, 2012 01:42 AM
compulady5
How-To: Mechanical
16
Jul 16, 2011 10:47 AM
Dr.Fingers
Jul 16, 2009 05:12 AM
CBR1000
TRG Coating
Mar 24, 2008 10:35 PM
