Preload sag without the included wrench
Is there a way to adjust the preload on the rear shock without having the wrench made for the specific purpose? i have the 06 F4i and it did not come with one. I need to adjust the preload because i have been riding 2 up alot and im running 2in slack in the chain to get the tension correct with stock preload. I also want to adjust is more to suit me more(6'2" 200lbs) on the everyday commute. I would appreciate any advice guys. Thanks in advance
You're going to need a spanner wrench of some sort. Out of desperation I used a pipe wrench once although definitely expect to beat up the metal collar pretty good if you decide to do that. The other day I was fortunate enough to find an old spanner/adjustable wrench type deal in an old toolbox for plumbing.
Anyway aside from finding/borrowing/buying a tool you could always remove the shock.
compulady5
How-To: Mechanical
16
Jul 16, 2011 10:47 AM
