PLEASE HELP..Starting issues
Old Mar 15, 2012 | 06:24 PM
craigs2002cbrf4i's Avatar
Default PLEASE HELP..Starting issues
Hello all, Thank you for helping me in advance. Ok heres the problem. I have an 2002 cbr f4i It starts will run all day long as long as you dont turn it off. The second you turn it off and go to turn it back on it just trys and trys to turn over but wont, now heres the funny thing, take it home let it sit till next day turn it on and it fires right up. drive it turn it off and nothing again. Please and Thank you for all your help.
Craig
Old Mar 15, 2012 | 06:52 PM
74demon's Avatar
when it wont start, do you hear the fuel pump priming?
Old Mar 15, 2012 | 06:56 PM
02cbraf's Avatar
Default got you covered
I am glad i can finally help someone out. i had the same problem with mine. After changeing the battery and taking it to the shop 2 times they finally told me that the Regulator Rectifier is getting hot and shutting off. I replaced mine with a Ricks Rectifier and no problems however the bad rectifier made my battery go bad so i got a new one free (warrenty) Hope this helps let me know.
Old Mar 15, 2012 | 06:57 PM
yes, everything just like normal wants to turn over but no spark, till the next day, already been threw all the grounds also.
Thank you for your reply
Old Mar 15, 2012 | 07:06 PM
MadHattr059's Avatar
Here's a link to doing the diagnostics on the r/r and charging system.
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
Good chance this is the issue, however check all of the connectors in the harness,
as well. Look for any sign of heat damage. Usually, the issues that come and go are
electrical/heat-related. If you find any signs of heat-damage on a connector,
closely inspect/test whatever component that connector goes to.
Hope that helps, Ern
Old Mar 16, 2012 | 10:16 AM
HellrazerinDC's Avatar
Sounds exactly like the issue I posted about that Ern had suggested about checking the connections for clean connections, etc.
Old Mar 16, 2012 | 11:12 AM
Default thank you all
Thank you all for your help I will defintly be testing that and will let everybody know if that is the issue, Hopefully I can get it going and be riding soon.
Thank you again everybody
Craig
Old Apr 3, 2012 | 08:46 AM
UPDATE.......Thank you for all the help, It was the Regulator Rectifier, got a new one put it in and PERFECT. Thank you 08cbraf, and everybody for looking at the post and all your help
AMSOIL929
Jul 16, 2013 12:14 PM
bburke88
Nov 8, 2012 12:37 PM
graygeezer
Jun 15, 2011 08:47 AM
thegatekeeper14
Jul 11, 2009 02:32 PM
ffry6326
Apr 8, 2007 12:45 PM
