PAIR removal
Old Feb 22, 2011 | 10:15 AM
heyitsmelam's Avatar
Default PAIR removal
Just finished removing the PAIR system yesterday and installed some Driven block off plates. It doesn't do much, like shed a 1lb or 2, but the popping from decelerating is gone. also, this could be a placebo affect, but throttle feels smoother through the low rpms.
if you guys just want a mod to add to the bike and have run out of options, i suggest doing this mod. it's cheap, relatively easy to do, and an easy way to tinker with the bike and learn.
you won't gain much or hurt anything if you try this out.
most stunters do the PAIR mod/klean air mod, but i just chose to do the block offs and removal.
any questions or interest in doing this, i'll be more than glad to help.
Old Feb 22, 2011 | 10:46 AM
jp_greenville13's Avatar
huh?
Old Feb 22, 2011 | 11:10 AM
nickels's Avatar
I Can't Sell On CBRF
Originally Posted by jp_greenville13
huh?
sounds like instead of T'ing all of them together he just blocked off the inlets
if you dont know what he's talkin about all together then ill explain....theres 3 tubes coming off the valve cover and they need to be t'd back into the valve cover
it frees up some hp and you lose the excess weight of the stock stuff which isnt much...definately a mod that should be done
Old Feb 22, 2011 | 11:22 AM
this
http://www.peterverdonedesigns.com/600RRpairsmog.htm
Old Feb 22, 2011 | 11:58 AM
Ah...I've never hear it referred to as PAIR before. I understand now. Thanks for clarifying. Lol
Old Feb 22, 2011 | 06:46 PM
MuscleswitCBR's Avatar
I've never heard of doing this... Does this hurt anything, is it hard to do? Is it something worth doing? Whats needed? Thanks
Old Feb 22, 2011 | 07:25 PM
Not hard to do. Doesn't harm anything (may turn on your FI light though? can someone verify?), Easy to do if you know how to tear your bike down past the fuel tank. Worth doing if you work on your bike alot or if your bike pops on decel. Needed are basic tools
Old Feb 22, 2011 | 08:19 PM
xtremef4i's Avatar
Removing the PAIR will not cause the FI light to turn on. Also, NO hp, or performance is gained from this mod even though many think there are gains to be had. The only reason I did this mod was to get a more accurate air/fuel reading before I had my dyno tune done. With the PAIR sytem on the bike, it allows unspent exhaust back into the airbox for cleaner emisions, resulting in a leaner reading on the exhaust sniffer. I think I said that right. Its been a while since I researched it.
Old Feb 23, 2011 | 12:22 AM
the PAIR system was designed for emissions regulation. removing it does no harm to the bike. some say the the PAIR mod is better than doing the PAIR removal. most stunters do the mod because it eliminates the chance of hydrolock.
regardless, everyone is pretty much right about the "benefits." every good dyno shop would disable the PAIR system before tuning. you won't have any popping when releasing the throttle. you take a pound or two off the bike, if you care for that sorta thing. and i found that the general location is less messy, making it easier to check the your plugs.
i bought my block off plates off of motomummy, grabbed my sockets and screwdrivers, and went at it for an hour or two. easy job.
now the PAIR mod is even cheaper but i didn't go that route.
here:
http://www.stuntlife.com/forums/443-...-636-a-15.html
http://cbrworld.net/forums/thread/248171.aspx
http://www.600rr.net/vb/showthread.php?t=168221
Old Feb 23, 2011 | 09:39 AM
nickels's Avatar
ok so you think unspent exhaust gases in the airbox doesnt hurt the hp? The bike wants and needs clean air. It might not be much but it does help.
