overheating
Old Aug 24, 2013 | 03:37 PM
dgk600f4i's Avatar
Default overheating
Bike overheats at idle when im ridding its fine. Not too sure where to start looking thanks
Old Aug 24, 2013 | 03:40 PM
74demon's Avatar
Does your fan come on at temp?
How hot does it get?
Old Aug 24, 2013 | 03:49 PM
dgk600f4i's Avatar
Yes fan comes on gets up til 250 260 ive seen it i always shut it off when it gets that hot. Also the tempature will jump 20 30° at a time say 200 til 230 then back and forth like that.
Old Aug 24, 2013 | 03:55 PM
74demon's Avatar
Coolant full?
Old Aug 24, 2013 | 04:02 PM
dgk600f4i's Avatar
Yes radiator is full. Resivor is about 80% full
Old Aug 24, 2013 | 04:21 PM
74demon's Avatar
Next step is to make sure the thermostat is opening properly and the cap holds pressure.
Old Aug 24, 2013 | 04:22 PM
dgk600f4i's Avatar
How do you do that not even too sure where the thermostat is located
Old Aug 24, 2013 | 04:30 PM
74demon's Avatar
Its located in the housing near the throttle bodies.
To see if its working in the bike, start the engine from cold. The lower hose wil gradually heat up, while the upper hose should be cooler. When it reaches temperature, the upper hose will quickly get as hot as the lower hose.
Or, you can take it out and put it in a pot of boiling water. When it gets hot, you will see it open or not.
Old Aug 24, 2013 | 04:40 PM
dgk600f4i's Avatar
Okay i will give it a shot in the next few days when i have some free time and i will.post back with the results
aan310
Oct 7, 2013 06:34 AM
StriperAngler
Jun 27, 2010 10:15 PM
tommyo4
Jun 9, 2010 05:12 PM
tommyo4
Jun 1, 2010 11:25 AM
98dakota
F2 Tech
Mar 29, 2010 10:10 AM
