overheating
Bike overheats at idle when im ridding its fine. Not too sure where to start looking thanks
Does your fan come on at temp?
How hot does it get? |
Yes fan comes on gets up til 250 260 ive seen it i always shut it off when it gets that hot. Also the tempature will jump 20 30° at a time say 200 til 230 then back and forth like that.
Coolant full?
Yes radiator is full. Resivor is about 80% full
Next step is to make sure the thermostat is opening properly and the cap holds pressure.
How do you do that not even too sure where the thermostat is located
Its located in the housing near the throttle bodies.
To see if its working in the bike, start the engine from cold. The lower hose wil gradually heat up, while the upper hose should be cooler. When it reaches temperature, the upper hose will quickly get as hot as the lower hose. Or, you can take it out and put it in a pot of boiling water. When it gets hot, you will see it open or not. |
Okay i will give it a shot in the next few days when i have some free time and i will.post back with the results
