Older Mileage F4i's Come In Side
Old Nov 29, 2011 | 05:39 PM
  #21
John Cu's Avatar
Bike: 2005F4I
Mileage: 56,000 kms
Problems: The CCTL its making a little noise, at 45k the Neutral sensor was changed and just the regular maintenance (chain, brake pads, oil, filters)
Old Nov 29, 2011 | 06:22 PM
  #22
OZZY_F4's Avatar
bike: 2001 f4i
klms- 69000,around 45000 miles
problems - fuel pressure reg, normal wear and tear components, had a broken wire in a coil plug that caused it to break down,laid it out about a year ago at 65 clicks, cosmetic damage only, replaced the fairings and snapped a chain 2 weeks later at 150 clicks and blew the tail of the bike apart. havent had any ctt problems guessing previous owner had it replaced. i love the thing i can cain it all day and it loves it.
Old Dec 6, 2011 | 04:38 AM
  #23
silentkillz1's Avatar
2002 f4i
51k miles
Doesn't seem to have any problems and it rides great. Just needs a brake fluid flush
Old Dec 6, 2011 | 08:26 AM
  #24
cnicosiaF4i's Avatar
Year: 2001
Mileage: ~52,000
Problems: Speed sensor, and I needed a new low beam bulb once....
Old Dec 8, 2011 | 04:55 PM
  #25
R Dub's Avatar
October 2011 ROTM
I'll chime in with my old F4i
Year: 2001
Milage: ~18000
Problems: Left me stranded 3 times. Finally figured out it was due to the headlight subharness that plugs into the main harness by the left air intake. The harness would come apart ever so slightly and kill the fuel pump. Zip tied that together and ran great ever since. Also towards the end of when I owned it the cluster would randomly reset itself on a ride. It would go off for a split second then do the start up sweep then reregister me speed, rpm, etc. It never reset the clock or trip. Never did figure out what that was. It only happened 2 or 3 times though. Other than that it ran great, even after I laid it down at about 30 mph and broke the stator cover and misc. stuff.
Old Dec 8, 2011 | 05:14 PM
  #26
saturncar's Avatar
bike 01 f4i
miles 26000
problems none so far other than basic maintenence
Old Dec 11, 2011 | 01:51 PM
  #27
dveldtf4i's Avatar
Bike:2003
Mileage: just dinged 50k coming home Friday
Problems: not too sure since I got the bike with 43k. Slight electrical problem, cctl changed And needs it again. Fork seals at 49k. Needs valves checked and spark plugs but otherwise running healthy.
Old Dec 13, 2011 | 01:27 PM
  #28
Stims9250's Avatar
bike: 01 F4i
Mileage: mid 20,000
Problems: The only main problem i have had with the bike is speed sensor. The bike has been completly totaled twice due to stunting and still have had no issues. The f4i motors are bulletproff.
Old Dec 12, 2012 | 03:09 PM
  #29
brickaries's Avatar
This thread is awesome! I've always wanted to know about how much more I can expect to get out of my baby. Looks like so long as I keep the wheels facing down, I should be good to go for some time to come!
2001 F4i
28,000 miles
no problems so far... just things vibrating loose from time to time... normal stuff... a screw here a battery cable tightening there... and I've laid it down twice...once around 15-20 mph nailed a curb from not leaning it enough...dented the rim... blew the tire...the other time 25-30 mph doing wheelies...dropped my fairings and that's when it became a streetfighter... lol. It'll have it's clothes back on again next spring...
I love this bike... I'm glad I went with Honda reliability when it comes to their engine technology...very robust...VERY
Old Dec 12, 2012 | 05:34 PM
  #30
Inknsteel's Avatar
Great thread! This is my first bike and only had it for a few months and put on around 1500 miles.
2002 F4i
29800 miles roughly (think the sprockets were changed by PO, speedo is off about 20mph)
Nothing major so far. Replaced Rectifier/Regulator recently after it died on me, fork seals repaired, blinkers, taillight LED's and battery. Starting to get a little ticking so possibly CCTL this spring with some new tires. Previous owner said it was laid down in a garage but there is slight rash on both sides of the bike so not 100% sure it was only laid down once. Other than that it's great, love this thing and can't wait for the spring to get back out on it!
