Is this normal?
Old Mar 26, 2010 | 06:39 PM
i2iSTUDIOS's Avatar
Default Is this normal?
So on my 2003 F4i, When i turn the throttle, the first 1/6th of a turn doesn't do anything, it is absolutely not turning the throttle body there is no resistance at all. Twisting the rest of the throttle is normal and smooth. so is that normal?
Old Mar 26, 2010 | 07:26 PM
chetman7's Avatar
there is some play in the throttle before there is resistance..you can adjust it to your like though. I like a little play before the throttle catches.
Old Mar 26, 2010 | 09:32 PM
downtown1's Avatar
Also you want a little play in the cable because as you turn the handle bars one way or another it tightens up and could cause the bike to accellerate during a turn.
Old Mar 27, 2010 | 03:09 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
1/6 of a turn sounds like you have excessive play in your throttle. The manual states that freeplay should be at 2-6 MM (1/4" max). You can perform minor adjustments from the handlebar end, otherwise you'll have to adjust it at the throttle body side. Section 3-4 in the Service Manual.
Old Apr 3, 2010 | 01:49 AM
motorhorse's Avatar
1/6 does sound a little excessive...are you sure thats an accurate reading?
Old Apr 3, 2010 | 07:45 AM
i2iSTUDIOS's Avatar
Oh yes that was accurate, I adjusted it, all good now, riding is a whole lot better.
MT Wallet
Aug 2, 2008 12:43 AM
minur505
May 11, 2007 04:08 PM
FiremanE4
May 5, 2007 06:33 PM
danny600rr
Dec 14, 2006 09:57 PM
drksidr
Apr 28, 2005 07:21 AM
