new chain suppose to have tight and loose spots?
Old Sep 5, 2007 | 07:12 PM
axsys's Avatar
Default new chain suppose to have tight and loose spots?
hey guys. i just put a brand new set of sprockets and a DID 525 x ring chain on. i adjusted it just fine, put about 50 miles on it, and decided to check it again today. i noticed that it already has tight and loose spots on the chain. is this normal for a brand new chain?
________
PERCOCET NOT WORKING ANYMORE
Old Sep 5, 2007 | 07:13 PM
TheX's Avatar
Default RE: new chain suppose to have tight and losoe spots?
Is it lubed properly?
Old Sep 5, 2007 | 09:57 PM
purpletj's Avatar
were you popping the clutch or running it hard?
Old Sep 5, 2007 | 11:42 PM
axsys's Avatar
yes it was lubed properly, and yes i was running it kinda hard. will it just even out over time?
________
Uggs
Old Sep 6, 2007 | 02:18 PM
Tahoe SC's Avatar
give it some time...and lube it when the chain is warm!!!
Old Sep 6, 2007 | 11:41 PM
axsys's Avatar
thanks tahoe, i figured you would know what to do. i also noticed something weird though. if my master link is at the bottom of the chain between the 2 sprockets, and is tight, if i rotate it around twice to the same spot, its now loose. so maybe its something else, like a sprocket?
________
DOMINICAN REPUBLIC RECIPES
Old Sep 7, 2007 | 10:37 AM
Tahoe SC's Avatar
yoooooo...check your sprockets, i don't think they are the super duper high performance 'wave' sprockets (like the rotors).
sounds like your sprockets aren't round.
check your chain very carefully for very tight spots and also look at the sprockets very carefully.
Old Sep 22, 2007 | 03:55 PM
axsys's Avatar
well tahoe you were right of course. i swapped my rear sprocket out today for the stock one and my problem is gone. you think the sprocket was cut bad from the company? its a drive systems sprocket, and i got it through sprocketcenter.com. i guess ill have to see if they will take it back on monday.
________
LOVE QUOTES ADVICE
Old Sep 22, 2007 | 07:27 PM
Gringo's Avatar
ORIGINAL: axsys
It must have been, assuming all of the teeth are in tact.
dcb2231
Dec 23, 2014 03:00 PM
OneFastGSR
Sep 27, 2012 12:23 AM
joelacer
May 23, 2010 12:44 AM
Muz
Mar 22, 2006 07:02 PM
clean929
Jun 21, 2005 12:24 PM
