My 1st Thread - Need help with Chain & Sprokets kit
Old 09-19-2013, 12:35 PM
05f4ii's Avatar
Guys,
What do you think of the following -
525 Superlite RS7 Steel Sprocket Set
AND going a -1 tooth in the front...How much difference will it make in MPG vs Acceleration gain...and overall RPM's/bike's overall performance. I am MORE focused on getting the MPGs. However, I don't mind losing 1-2 MPGs if I'll get a gain that's worth it...(compared to stock). OR I can just keep it stock, no problem! Love the bike anyway. I "need" a chain ASAP guys......so please help me.
Thanks in Advance!!!!!!!!!
Old 09-19-2013, 05:12 PM
05f4ii's Avatar
^ ^ okay! so now back to the issue at hand.
Old 09-19-2013, 09:08 PM
jeffjones's Avatar
Originally Posted by 05f4ii
Guys,
www.gearingcommander.com
You can play with sprocket changes and see what your rpm changes will be
Old 09-22-2013, 11:10 AM
Bryce Swartzwelder's Avatar
Your one tooth difference will result in 6.7% difference overall. How you ride and your local terrain will determine your mpg. I can't see ANY reason to consider a 530 chain, the extra weight on the driveline isn't worth it unless you have HUUUUUGE horsepower. There are a lot of liter bikes that come stock with 525 chains. If anything i would use a lighter 520 conversion to save on weight. Just my opinion. Less rotating weight = quicker acceleration. Todays quality 520 chains are strong enough to handle it provided you aren't a wheelie freak.
Old 09-25-2013, 10:03 AM
05f4ii's Avatar
Thanks for the help guys....
So, I would be getting ALL steel sprockets - DID, RK, or EK chain. I am also learning that the 520 conversion (with good quality chain) could last just the same as 525 (stock). Not sure which I'll get, but Im considering either type.
Only the price, and "good buy" is the next thing....Any links or vendors that have good pricing..??
Thanks again guys....
Old 09-25-2013, 06:12 PM
RudyGT's Avatar
Old 09-25-2013, 07:08 PM
"A"'s Avatar
"A"
"A" is offline
525 vs 520 chain longevity... if you're not pulling wheelies or running trackdays every weekend... 520 chain conversionn is the way to go.
520 kits cost less, weigh less, with regular maintenance likely to last just as long if not longer than 525 kit.
Keep in mind that longevity of chain and sprockets is maintenance, keep them clean and lubed, they will last.
Maine cbr rider
05-26-2012 04:54 PM
osin41
10-01-2009 04:39 PM
Mstngdrew232
02-20-2008 05:20 PM
spudmn439
11-27-2007 11:13 AM
fast929
04-17-2007 07:14 AM
Quick Reply: My 1st Thread - Need help with Chain & Sprokets kit
