motor temperature problem!!!
Old May 11, 2008 | 12:29 AM
moldousa's Avatar
Default RE: motor temperature problem!!!
no man... my bad it's 219 not 119., and my bike has 23k on it., and it's time to change the clutch, cause I think that the previous owner ran the bike pretty hard...
Old May 11, 2008 | 01:45 AM
FLYOU's Avatar
225-230 is normal when stopped. Anything above 230 is hot. 254 and the engine light comes on so don't worry about it. I've hit 230 when it's been 40 degrees out so the outside air temperature doesn't matter. Air flow is what's important. You can leave your bike running outside unattended when the temp is 100 degrees outside and she'll be fine running at 230 degrees.
Old May 11, 2008 | 12:17 PM
Jaybird180's Avatar
I agree with FLYOU. I run the crap out of my bike. Red line, rev limiter. Full throttle.
I don't do burnouts or stunts. And I use only distilled water and water wetter in my cooling system. Runs a bit higher than if I ran engine ice but it's also my trackday bike. So rather than change it, it goes H2O 365/yr.
Jinvl
F2 Tech
24
Dec 22, 2013 11:01 PM
kawc
Jul 16, 2011 10:59 AM
Timothy
Jul 4, 2009 06:25 PM
CrashParkman
Jan 16, 2008 02:53 AM
Famous_sns
Jul 19, 2006 01:37 AM
