Lightweight front rotors for the F4i?
What advantaged do you think more leverage will result in? Either way, even the crappiest stock brakes have more than enough force to LOCK the front wheel, which means that, again, the limiting factor is the tire, not the brakes.
There are many factors when considering brake systems. Fluids, pad compounds, rotor designs. Total braking force is not normally one of those considerations when it comes to motorcycles.
You are correct. I should have said less heat in the system. Larger rotor means more material to absord the heat before it transfer to the fluid. Larger rotor also means more surface area to act as a heat sink and transfer the heat to the surrounding air. The end result is the same, less heat in the brake system as a whole.
