license plate bulb
Old 03-08-2012, 07:28 PM
cbr600f4i13's Avatar
Default license plate bulb
ok i am stumped here i am trying to figuer out how to get the stock license plate bulb out so i can replace it. also what size bulb is it in the stock houseing. If anyone has some pictures that would be great to.
Old 03-08-2012, 08:29 PM
jeffjones's Avatar
Here si the layout of how it connects along with part numbers.
Ronayers.com Microfiche Honda>Motorcycle>2001>CBR600F4>REAR FENDER 01-03
Old 03-09-2012, 01:19 PM
Incompatible's Avatar
To expand a little on the diagram which Jeff posted. You need to remove the license plate/tail light assembly by removing the two attachment bolts from the underside of the fender. After removal, you can disassemble the light by removing the two screws at the back of the housing. Reassemble in reverse order.
Old 03-09-2012, 04:38 PM
jeffjones's Avatar
Good, I have an undertail with LED license bolt lights so I wasn't sure on the disassembly of that bracket.
Old 03-09-2012, 06:19 PM
OP, sorry, forgot to give you the bulb designation: 3157. Easy to find. If ones gone out, replace them both, it will save you time from doing the other down the road.
Blackdog91
06-12-2013 12:59 AM
gump
04-11-2010 07:09 PM
6doubleohf3
How-To: Mechanical
05-01-2009 01:59 AM
ffingers
10-10-2007 05:34 PM
danadeny
06-25-2007 02:04 PM
Quick Reply: license plate bulb
