license plate bulb
Old Mar 8, 2012 | 07:28 PM
cbr600f4i13's Avatar
Default license plate bulb
ok i am stumped here i am trying to figuer out how to get the stock license plate bulb out so i can replace it. also what size bulb is it in the stock houseing. If anyone has some pictures that would be great to.
Old Mar 8, 2012 | 08:29 PM
jeffjones's Avatar
Here si the layout of how it connects along with part numbers.
Ronayers.com Microfiche Honda>Motorcycle>2001>CBR600F4>REAR FENDER 01-03
Old Mar 9, 2012 | 01:19 PM
Incompatible's Avatar
To expand a little on the diagram which Jeff posted. You need to remove the license plate/tail light assembly by removing the two attachment bolts from the underside of the fender. After removal, you can disassemble the light by removing the two screws at the back of the housing. Reassemble in reverse order.
Old Mar 9, 2012 | 04:38 PM
jeffjones's Avatar
Good, I have an undertail with LED license bolt lights so I wasn't sure on the disassembly of that bracket.
Old Mar 9, 2012 | 06:19 PM
OP, sorry, forgot to give you the bulb designation: 3157. Easy to find. If ones gone out, replace them both, it will save you time from doing the other down the road.
Blackdog91
Jun 12, 2013 12:59 AM
gump
Apr 11, 2010 07:09 PM
6doubleohf3
How-To: Mechanical
May 1, 2009 01:59 AM
ffingers
Oct 10, 2007 05:34 PM
danadeny
Jun 25, 2007 02:04 PM
