Led
Old Jul 22, 2011 | 04:14 PM
jeffjones's Avatar
Originally Posted by jtf4nq
Do you think I'd need all thatvto make it look halfway decent?? I'm not wantin to spend quite so much $$$
Thats just what I ordered their kits start at $27.
Blue Motorcycle LED Lights
Old Jul 22, 2011 | 04:15 PM
CodyJ28's Avatar
what about something like this?
HONDA CBR 600RR 1000RR F4i 954 929 UNDERLIGHTING KIT | eBay
Old Jul 22, 2011 | 04:59 PM
jtf4nq's Avatar
Sweet, do you happen to have pictures? That's be awesome to see what the 12 piece looks like.
Old Jul 22, 2011 | 05:49 PM
jeffjones's Avatar
I will whenever they get in and I install them
Old Jul 24, 2011 | 12:38 AM
CodyJ28's Avatar
these look pretty decent also
8pc MILLION COLOR LED MOTORCYCLE UNDER GLOW LIGHT KIT | eBay
Old Jul 24, 2011 | 01:38 AM
jtf4nq's Avatar
Dang. I don't know which to go with. All look like they'd work well. Has anyone installed a kit on their bike that they were pleased with? And maybe pics of it??
Thanks
Old Jul 24, 2011 | 03:29 AM
supersnake83's Avatar
Awesome!! How difficult are they to install? Or any LEDs for that matter. Also, how long of strips and how long of strips did you buy, and how did it look???
Install is very easy. My main bright lights are two 9.7" LED's on each side of the frame of my F4i (underneath the part that is exposed. They are hidden from view) and two 2.4" inside the front fairing below the air intake openings.
I also have 4 pre-wired 6" ribbon strip LED's. Two under the front part of my seat and two under the back part of my seat (didn't really need the two under the back part of my seat, but I bought too many when I made my purchase, so I had to improvise). I also have one 2.4" that is under the bottom center of my bike.
The Oznium LED's have a positive/negative and I wired all of the LED's in parallel and split them connecting them to the A and B side of the flash module to split the dimming and strobe effects, and to be able to turn them off/on when I want. Then from that control switch to a 3A fuse then to my battery.
All included good double sided tape, so they stick on really well.
For me, it looks great. I just went with a red and white LED scheme. Bright enough at night and they produce nice ground effects.
Edit:
Oznium now have pod lights and accent lights for motorcycles. They are are great design because they are small and can be put in more placed to get a more desired effect.
Old Jul 29, 2011 | 05:06 PM
Aken's Avatar
July 2008 ROTM
Originally Posted by Kuroshio
Haven't figured out how to work the canon in low light without the flash.
Tv mode (shutter priority) + tripod.
+1 to Oznium. I know Ebay can have some cheap stuff, but you run the risk of getting cheap lights in return. Oznium has reviews and detailed info on almost all products right there to see, plus warranty and customer service.
Old Jul 29, 2011 | 06:06 PM
jeffjones's Avatar
I just got mine in today along ith my ne fairings, if I get everything installed in time I ill and pics.
I got the 12pc ledglow kit and by the looks of it will be putting 10 on and saving the other 2 for when my tank gets painted.
The ledglows LED's look like they are the exact same as oznium's except they are all plug and play.
Edit adding pics:
All strips will be hidden once the body goes on. and this is just a first shot might change once I see it at night.
I will hopefully be done everything so I can take night pics once my daughter goes to bed.
Strip on intake baffle, 1 on frame and on going across lighting everything
In the rear pegs to light up the tires:
Behind the license plate to light up tire:
between battery box and tank to light up shock:
On frame and intake baffle:
The one going through to light up the engine:
Old Jul 29, 2011 | 09:47 PM
jeffjones's Avatar
Just got the cbrfairings.com fairings almost fully done, need the windscreen and a couple wellnuts, but here is the pics with the lights and fairings on.
Don't mind the $#itty photography:
