Just installed the PCIII
Old May 15, 2008 | 12:08 AM
krobberts's Avatar
Default Just installed the PCIII
I got a PCIII from a guy for $150, and honestly I was kind of concerned that it wouldn't work. The only reason I was concerned is that it had been on Craigs list for like 3 weeks, for $150 and nobody had grabbed it. I hooked it up, and it seems to work pretty well. The only issue I see is not with the PCIII, but more the design of the PCIII. It does not appear that you can load maps, or retrieve maps without the engine running. Im wondering if this will help my gas mileage at all. I am also wondering if anyone has a map out there for maximum gas mileage. But, long story short.. the install was pretty easy, and it works. I haven't taken it out for a spin yet, but it is in.
Old May 15, 2008 | 02:10 AM
kneepuck oo envy's Avatar
Default RE: Just installed the PCIII
you can load maps with the 9V power adapter...should have came with the kit...if not, theyre available on dynojets site for about $14...makes life a helluva easier than hooking it up to your bike for power and getting a laptop...
Old May 15, 2008 | 09:12 AM
krobberts's Avatar
I got it used, so it doesn't have any of the extras that came with it. Literally all I got was the unit itself. I ran a USB plug from it to under the front seat. That way if I need to do some modification, all I have to do is pull the USB cable out. I'm thinking I might try and rig a USB plug somewhere on the bike, not sure where though. I also have the hot bodies undertail kit, so I need to find a good place to put the PCIII. Right now it's just sitting in my trunk. I need to find a good place to attach it.
Old May 15, 2008 | 11:00 AM
Ruftags's Avatar
I layed mine across the top of the center tray, and put mall holes on sides of tray and attached it with zip ties. The tool pouch fits back by the tail light. I lost most of the room doin it that way , but I can still attach usb cable and don't have to worry about unit getting hot ( not that I noticed much heat from it anyway). I just didn't want it bouncing around in there.
Matt5606
F4i - Wanted
Apr 17, 2011 02:04 PM
Diablo Runner
Jul 5, 2008 05:00 PM
doogstar
May 7, 2007 05:44 PM
Turnin20s
Jan 19, 2006 12:40 PM
