Instrument & tail light out at same time?
Old Nov 5, 2012 | 03:05 AM
rcncbr's Avatar
Default Instrument & tail light out at same time?
Second day riding my newly purchased 04 and the instrument cluster and tail/brake lamp stops working while riding on highway. Instrument cluster reads zero rpm and not lit from what I can see, friend told me tail lights are out.
Fuse? Some type of common connection broke? where should I start first? Mechanically inclined but new to bikes.
Thanks.
Old Nov 5, 2012 | 10:51 AM
Shadow's Avatar
Check the connector blocks - they sometimes work loose
You'll probably find them near the rear of your instrument panel or in the right side front.
Tail lamp could just be a bulb..................
Old Nov 5, 2012 | 10:56 AM
74demon's Avatar
Start by checking the fuse. There is a 10a fuse that is common to those circuits.
Old Nov 5, 2012 | 02:06 PM
rcncbr's Avatar
I'll check those two. Thanks.
Sucks that with this gas shortage we're having in the tristate, I can't tell if I'm on reserves.
Old Nov 5, 2012 | 05:44 PM
raylee's Avatar
Likely the fuse. Where in the tri-state? If you go down to south Jersey towards Princeton/Hamilton/Trenton area there are no lines at the fuel pumps and they're not even doing the odd/even thing.
Old Nov 5, 2012 | 07:18 PM
rcncbr's Avatar
It was the fuse. Fuse is same for tail/instrument.
I'm in NYC area. I heard but I hate jersey, I'll probably head to CT instead.
Ghost1
Jul 15, 2013 11:35 PM
xdaddyxspudx
May 2, 2013 03:01 AM
Migge
F2 Tech
Apr 17, 2013 04:51 PM
rcb7601
Aug 27, 2009 01:26 PM
