Installing bar end mirrors (help)
Old Jun 8, 2009 | 07:48 PM
mbison83's Avatar
Default Installing bar end mirrors (help)
Ok guys. So I've ordered some nice bar end mirrors for my 04 f4i. Just got them today and I ran into a problem when trying to have them installed. I've taken the current bar ends off only to find out there is this metal piece right behind it, which prevents me from inserting the mirrors into the handlebars (check pix).
After looking at the service manual I figure they are the inner handlebar weights, which I've tried to move but was unsuccessfull. Can anyone tell me how to do this? Any help greatly appreciated. Thanks.
Attached Thumbnails Installing bar end mirrors (help)-0608091652a.jpg   Installing bar end mirrors (help)-0608091652.jpg   Installing bar end mirrors (help)-0608091653.jpg
Old Jun 9, 2009 | 12:20 AM
dftsupra's Avatar
did you try screwing in a screw and pulling it out?
Old Jun 9, 2009 | 12:29 AM
PlayfulGod's Avatar
thats what the barend screws into and posse to lock it in place.
your mirriors look as they pose to mount to a hollow bar like aftermarket ones are n not the solid ones like the stock ones are.
Old Jun 9, 2009 | 01:46 PM
mbison83's Avatar
yes ive tried that. it does not move.
Old Jun 9, 2009 | 01:47 PM
mbison83's Avatar
so you think i should get aftermarket handlebars?
Old Jun 9, 2009 | 09:26 PM
cman9toes's Avatar
Ok according to the service manual, there is a tab tha you will need to bend down and then use the screw to pull the weight out. You will need to pull the grips off to expose the hole that the tab stickes up through.
Old Jun 10, 2009 | 12:41 AM
mbison83's Avatar
i see. i will definitely need a second pair of hands for that. do i just get rid of the weights after pulling them out?
Old Jun 10, 2009 | 08:18 AM
cman9toes's Avatar
I would think that you would not be able to keep them in there.
I remember a thead on here that someone filled the clipon with fishing weight to reduce vibration.
Why do you need another set of hands? Just bend the tab and pull it out.
use an air compresser to get the grips off.
Old Jun 11, 2009 | 02:50 PM
mbison83's Avatar
ok so i decided to take an alternate route by using different size screws (ones that fit in the inner weights) + some spacers. it looks good imo.
Phantez
Jul 6, 2011 12:07 AM
jmj166
Mar 3, 2010 07:17 AM
Napalm1000
Apr 1, 2008 04:14 PM
CBR55
Apr 15, 2007 12:48 PM
skimo0104
Dec 29, 2006 12:03 AM
