Indicator Lights on Cluster...
Old Apr 30, 2010 | 01:46 PM
vangill's Avatar
July 2010 ROTM
Originally Posted by zmds18
I think honda has it on there for safety reasons.. but it can be called whatever i suppose lol
A shift light is a warning lamp fitted to vehicles in order to indicate to the driver that maximum RPM has almost been reached. Ideally a shift lamp will illuminate at the engine speed beyond that which delivers the maximum BHP such that the BHP before and after shifting is the same. Accelerating the engine beyond this point is not conducive to rapid acceleration. In use a shift light allows the driver to judge the exact point that a gear change should be carried out without having to glance down at the tachometer. This also increases safety for the driver by keeping his focus on the track at all times.
this is pretty good, thanks
its what i was trying to say......i cant ever explain it right lol
Old Apr 30, 2010 | 01:48 PM
__Z__'s Avatar
April 2011 Ride of the Month
lol i stole it from wikipedia... that place has everything
Old Apr 30, 2010 | 01:54 PM
usetheffours's Avatar
I'd call it the "what the hell are you doing light" If it comes on for more than a second your doing it wrong
Old Apr 30, 2010 | 02:18 PM
james_hale2's Avatar
Originally Posted by StoobyMcDooby
thanks for input everybody.. a repair shop put a new coolant temp switch in for me, so it doesnt kick in until 234... it gets up into the 240's all the time... but never higher than that.. And the light still doesnt come on.
But as for the shift light, I always figured that it was a shift light and nothing else, until i talked to a mechanic who said that most all bikes 2000+ have check engine lights.. but i've never noticed one on mine..
thats to high. the manuals troubleshooting steps say if the temp reaches over 226 without kicking on the fan to check the fan by grounding the wire that is on the temp switch and if the fan comes on replace the temp switch. its supposed to come on at 225 and myself and others i know have replaced the switch with one that kicks on at 205 (i thinks its out of a prelude but not sure). but i have no idea why they would put a 234 in there.
Old Apr 30, 2010 | 02:24 PM
ohhh yeah and that light is not a shift light its a HEY! YOU FORGOT TO SHIFT YOU IDIOT! light. no vehicles optimum shift point is redline.
Old Apr 30, 2010 | 02:28 PM
__Z__'s Avatar
considering that your supposed to shift at the beginning of your redline... u should see it come on every gear
Old Apr 30, 2010 | 02:37 PM
on every bike and car ive dragged, taking it all the way to red line in each gear would produce a higher time. thats why aftermarket tachs with "shift lights" are adjustable so you can run your vehicle multiple times while shifting at different rpms to see which will produce the lowest time. then you set the light to that rpm. and alot of them will do multiple gears because the "shift light" is most often different rpms in different gears. but hey if you feel your bike is faster redlining every gear by all means its yours.
Old Apr 30, 2010 | 07:45 PM
StoobyMcDooby's Avatar
dayyyyum. Well I'm going to do that lower temp sensor swap that's in the DIY section... hopefully that will fix things...
Old Apr 30, 2010 | 08:33 PM
Kuroshio's Avatar
250 is overheat according to the manual. The higher you're climbing before the fan kicks in, the less cushion you got before bad things start happening
The_Polish_won
Mar 28, 2012 05:55 PM
TommyJ
May 6, 2008 11:22 PM
lxi226
Jul 21, 2007 07:51 AM
Sabor600rr
Jun 25, 2007 10:21 AM
sushix2
Feb 7, 2006 12:53 AM
