01 F4I Indicator lights & won't start
01 F4I rode for ~1 hr set for 10 min then turned on the key, put on my helmet went to start it and noticed the turn and high beam indicator lights were on as well. started for ~1sec and shut itself off keeps doing this. Won't start....anybody no what's going on????
Thanks in advance
Thanks in advance
RE: 01 F4I Indicator lights & won't start
Thanks, fuses look good. Thought it was the battery and tried jumping it immediately, also put it on the charger but no luck. Will try a new one b/c I have had issues with this one b/4. Wouldn't know why oil change should do this.
Initially thought I heard the fuel pump wind up but now nothing...would make sense the FI (fuel pump indicator light) is the only one not lit. Will try replacing the battery b/4 taking it in to have them hunt down fuel pump issues (if that's it).
Any other suggestions greatly appreciated.
Thanks again.
Thanks again.
search button...
Read, if none of that helps, let us know.
turn sigs come on? Sounds like what i just did, HEADLIGHT RELAY.
Do your headlights come on? If the relay goes bad, then the lights won't come on, and the bike shuts itself off, as safety precausion.
First, Check your fuses, see if any are bad... Find the headlight one, pull it out and try and start it...
Second, Check to see if the pin with the green wire (headlights i believe) is corroded and discolored on your upper sub-harness.
maybe you can check these threads out:
https://cbrforum.com/m_264549/tm.htm
https://cbrforum.com/m_259937/tm.htm
