Ignition mod
Old Jul 26, 2012 | 05:15 AM
C Jacob W's Avatar
Default Ignition mod
Is there an ignition timing mod for the f4i? Can you advance the timing three degrees or so for throttle response? Just wondering because my buddy did it on his Yamaha fz1.
Old Jul 27, 2012 | 07:12 PM
2wheelfury's Avatar
factory pro sells an ignition advancer. That would be the route you would want to go.
Old Aug 4, 2012 | 10:55 PM
xtremef4i's Avatar
Or I think the power commander IIIr allows ou to adjust ignition curve depending on throttle position. This would require a Dino tune though. Or the ignition advancer can bemused butit a fixed amount of advance. This is cheaper and easier to do... I don't think you will notice much gain if any though. At leat I didn't.
Old Aug 5, 2012 | 04:32 AM
C Jacob W's Avatar
Did you but it?
Old Aug 5, 2012 | 07:12 AM
xtremef4i's Avatar
I've got an adjustable one on mine. After all the reading I did from others doing it, I was expecting more of a midrange gain but couldn't notice much. Some people say the same thing and others say they noticed it. It's not too expensive so you aren't out much to try it if it's something you are interested in.
Old Aug 5, 2012 | 06:18 PM
C Jacob W's Avatar
Where did you buY it? I can at least look into it
Old Aug 5, 2012 | 10:48 PM
xtremef4i's Avatar
Got mine off eBay. Mine is RPM and is set at six degrees advance but can advance or retard from +10 to -10. Factory pro is most common and is four degrees advance is typically whay youll find on the f4i. Check eBay or amazon for the best deals.
Old Aug 10, 2012 | 01:59 AM
Joe Rocket's Avatar
Your best bet for a better throttle response would be to change your gearing...
Old Aug 10, 2012 | 05:18 AM
C Jacob W's Avatar
Its already changed -1+2
Alex Poucher
Feb 14, 2013 09:29 AM
DagonRais
Apr 14, 2011 09:32 PM
importluva85
Sep 21, 2007 01:32 PM
Junior
Oct 5, 2006 09:57 PM
