I fell off my F4i
Old May 15, 2009 | 12:13 AM
eljrc16's Avatar
Unhappy I fell off my F4i
So I officially ate it thrusday morning getting to work about to park when I guess I hit the
front brake to hard and it just threw me off and made my bike just slide off I got a few scrapes good thing I was wearing my jacket but It was only about 20 to 25 miles per hour.
On the other hand my bike got a broken back brake lever, a few scratches not much on the fairing but good thing I only have them primered, and the piping that comes out of the motor leading to the exhaust got a dent as well.
So now I am still going to ride but I know how it feels to fall so just be more careful. Also I have a project now to do sand off and primer.
Anybody know how much a mechanic would charge me to change my back brake?
Old May 15, 2009 | 12:26 AM
Aken's Avatar
July 2008 ROTM
You could change the pedal yourself with simple tools.
Old May 15, 2009 | 12:30 AM
eljrc16's Avatar
Its not that hard Aken? what do I need just a wrench to take off the brake lever how much is a new brake lever?
Old May 15, 2009 | 12:31 AM
Aken's Avatar
July 2008 ROTM
New brake levers are pricey, like $50. Unless you get an aftermarket one on Ebay, which I personally wouldn't do but I haven't heard anything specifically bad about them.
And I don't know what tools exactly off hand, just go take a look.
Old May 15, 2009 | 12:51 AM
Zero1080's Avatar
Yeah, my buddy dropped his, going a little faster, more or less jumped off the thing, long story. But had to replace his whole handle, minus the plastic for the light switch. It was a simple off and on in about 15-20 minutes.
Old May 15, 2009 | 08:49 AM
skoobydoobie's Avatar
DIY, it doesn't get much easier than that. DIY Wait till you decide to change the plugs or the CCT. Both are pretty simple too, just a matter of removing some pieces (fairings and tank). DIY If you don't already have tools, then I suggest going to sears and investing 100 bucks or so on a good set of basic tools, socket set, screwdrivers, and maybe some open end wrenches $$ permitting. Do yourself a favor and stay away from the taiwanese junk sold at the local autoparts stores. Did I mention Do It Yourself.
Old May 15, 2009 | 09:22 AM
midnightsparks's Avatar
zero u gotta tell that story
Old May 15, 2009 | 10:20 AM
mbison83's Avatar
its pretty easy. i've changed both, my gear shift lever and the brake lever on my f4i.
all you need is parts, toold, and a bit of patience. i did it even tho i've never worked on bikes before. and i saved $100 doing that (quote from a mechanic). good luck.
Old May 15, 2009 | 04:33 PM
Zero1080's Avatar
Midnight, he was in traffic, and basically was coming up to a light, and stood up to fix his pants, you know what I'm talking about. And a car swerved into the lane in front of him. So he leaned to the side to try and get out of the way, and just went a little too far, all while standing, so he kinda just stepped off and stumbled. Thank god it was a red light though, otherwise he probably would have been hit. But the bike only had some scratches up the side, and a broken handle bar.
Old May 15, 2009 | 04:58 PM
Jaybird180's Avatar
Ocassionally you can find a new rear brake lever, but since they are often bent out of shape, used ones can be pricey. They're easy to remove, you only need a pair of needle nose pliers to remove the circlip.
I suggest you begin investing in tools. If you're going to be in this hobby any length of time, you will learn to work on your F4i, which is an easy machine to learn on.
PS- Get a service manual too. I have a Haynes book and .pdf Honda service manual and use both.
kgarrison4420
Mar 29, 2010 09:05 PM
paulb51
Mar 23, 2010 07:18 PM
kcinobro
Sep 12, 2007 10:38 PM
Marker54
Sep 4, 2007 02:21 PM
snowboarding82
Aug 13, 2007 07:26 AM
