HOW DO I LOWER MY 01 F4I
HEY GUYS IM WANTING TO LOWER MY RIDE ABOUT ONE INCH AS IM PUTTING ON MY REPSOL FAIRINGS AND JUST WANT A LITTLE LOWER STANCE SINCE IM PUTTING ON A 190 TIRE IN THE REAR HOW DO I ACCHEIVE THIS
why n why? both of those will affect the handling of your bike in a negative way.
But..
The correct way to lower it is to get a lowering dogbone for the rear. And to cut your fork tubes etc cut 1" shorter, but most ppl halfass it n just raise them up in the triple trees. Again this will reduce your lean angle n completely throw the handling off compared to what its meant to be, esp if your ride twisties n such.
But..
JB...welcome to the site. You don't have to post in all caps if you don't want to. Lowering the bike, and putting on the biggerskinwill absolutely compromise your ability to corner. What do you want to get out of your motorcycle? Your ride is only for you, but if you want to corner, you are better leaving the rear alone and getting a pair of boots with tall tread. I bought a pair of boots thatmade me an inch and a half taller so I could stand flat footed at a light. If you wear a 10 1/2, I will be glad to send them to your for freight because I have a new set of boots, and I don't use my old ones anymore.
180/55/17 or a 190/50/17...... not sure there is inch there unless you are talking about a 190/55, but I have never put a tape to them? Don't forget, when you lower them you also reduce travel thus requiring new valving, shim stack and springs to make the most of what you have.
Thanks man for the offer... Im a 12 though " crap" man im tall im 6'1 I just see nikcy haydens bike and it looks lower then mine... And no its not because his seems lower i wanna go lower, i just think it would look alittle better.... I scratched the 190 tire idea i just bought brandnew dunlops last night.... So i guess the only thing to do now is find 2 honda stickers and get my tank painted orange... Whats a good boot run my friend
I have a pair of Sidi vertigos. You can get them at newenough.com for $275. Great protection n super comfortable. I wear mine anytime I ride regardless of where I am going.
I read an article on this, i think it was in a magazine called super streetbike, i'll try to find if you're interested.
It told exactly how to lower it an inch or two while keeping as much of your original handling characteristics as possible.
The biggest problem, once you get your suspension to work with the lowering, is clearance. You've already got a high-mount exhaust, maybe with some aftermarket rearsets you can get back to the original intended max. lean angles. (and you can get some rearsets that look BA as well.)
