HID flickering
Old May 3, 2012 | 09:28 PM
An01InAZ's Avatar
Default HID flickering
I bought the bike (2001 f4I) last july. Almost her birthday and I was in a traffic jam on the freeway this afternoon and my headlights were seen on the back of a prius. My highbeams were on and I noticed the "low beam" side was flickering on and off. So I was tripped out. It started doing today. When I got home I shook the bike side to side, nothn, up and down. Nothn...throttle....nothn. then I pulled the brake lever. It flickered. So I tried the brake again and it does the flickering. All I did was replace the 10k bulbs and reconnect everything. Any idea why this is happening? I don't want my battery to get used to power up the light to come on everytime I'm at a stoplight...
Old May 3, 2012 | 09:36 PM
The__Rider's Avatar
I had the same problem with my 600. I replaced the ballast, unplugged/replugged the connections, tested the battery. All nothing. I didn't have any results with the brake lever though. It would flicker for a little while then shut off completely. Might want to check your fuses? I had some fuses go bad a couple times and that seemed to be the problem. Otherwise it could be the bulb?
Old May 3, 2012 | 09:51 PM
Aken's Avatar
July 2008 ROTM
It's not a fuse issue - fuses are all or nothing when it comes to power.
HIDs flicker sometimes if there's a voltage drop. They also might flicker if they are nearing the end of their life span. Double check your connections just in case, and keep an eye on it.
Tweeek
Apr 15, 2012 03:58 PM
flyboy1294
Feb 22, 2012 06:49 PM
Vader
Sep 7, 2010 12:11 AM
SkoogusMaximus
Sep 7, 2008 02:25 PM
hobbs51
May 20, 2006 02:28 AM
