help with spitting oil and shooting flames
need help bad. my 03 f4i is shooting oil out of the exhaust and shooting flames from time to time. ive talked to a few people about this uncommon problem but no one has an answer. i narrowed it down to rings which i do not think are bad do to there is oil and what ive heard is that you will throw a rod before rings go out.. #2- i think there are rubber grommets in the head right below the head of the valve to guide it and seal the oil which i may believe are letting oil by to the cylinder and just trying to fire and wont. the build up pressure when fires throws a flame.. #3 possible valve stuck open.......
it is an 03 with 9k miles and was stunted.
Please guys let me know so i can fix this. im tired of this bike sitting and cannot ride it. it drives me iiiiiiiiiinnnnnnnsssssssssaaaaaaaannnnnnneeeeeeee.
Thanks.
Thanks.
Idk the issue well enough or more info on your bike, but run a compression text, sounds like the cylinder for 1 isnt always firing, needing new plugs. 2, sounds like oil rings are shot.
3, if it is indeed valve guides. in some cases its just easer to buy a new head.
i replaced all coils and also the plugs twice with iridium plugs which i blew through the first set and the second. the harness has no impedance and has the most powerful spark. the 2 and 3 cyl have oil build up, the 1st and 4th are firing super clean....
im going to do a compression test tomorrow... so ill guess that ill know then...
i do not have alot of money to buy another head but i do know labor and if its just the $10 seals ill go ahead and do that...
how much does a new and used head run for???
Thanks for the input. ill keep updating
Dam bro sorry to hear that. im working on getting my hands on a second f4i motor, just as a spair.
