Help - need to remove rear wheel
Old Jun 25, 2010 | 11:03 AM
DetroitF4i's Avatar
Default Help - need to remove rear wheel
2002 F4i.
I got new tires and tried to remove the rear wheel yesterday.
My axle nut wont budge.
Sprayed both sides with WD40 this morning and will try again this evening when I get home.
Wondering if there is only the axle nuts to remove or is there any other locking mechanism on it? I dont see any cotter pins or anything.
Anything else that I should try apart from using a longer wrench and more force?
Old Jun 25, 2010 | 11:40 AM
mk2mike's Avatar
I Can't Sell Because I'm Hardheaded
you just have to remove that 27mm nut on the axle (think its 27mm) and then push the axle through.... it's on there tight so yeah, may need a larger wrench
Old Jun 25, 2010 | 11:43 AM
redzintimidator's Avatar
yea its a 27...and i think the other side is a 22..make sure you hold the other side still :-p
Old Jun 25, 2010 | 11:55 AM
Kuroshio's Avatar
Breaker bar and a 27mm in the right. And you might want to get a friend to sit on the bike and hold the brakes with the bike in neutral if its really bad. Otherwise you'll be fighting the tranny which could cause damage.
Old Jun 25, 2010 | 11:59 AM
NateDieselF4i's Avatar
Kuro fights trannys all the time. He's the forum expert on the subject.
Old Jun 25, 2010 | 12:09 PM
Sick97SS's Avatar
Put a metal pole over the ratchet handle to get more leverage.
edit: damnit i took to long to post and kuro the tranny fighter beat me to the breaker bar...
Old Jun 25, 2010 | 05:49 PM
kowen1208's Avatar
Bahahahaha!
Old Jun 25, 2010 | 06:06 PM
Kuroshio's Avatar
Old Jun 26, 2010 | 08:50 AM
skoobydoobie's Avatar
Bring it over, I'm in the "Shacks" by the fire house, we'll git R dun.
Old Jun 26, 2010 | 11:00 AM
DetroitF4i's Avatar
Thanks for offering skoobydoobie, appreciate it.
I got a blade in my rear tire 2 weeks back while I was riding, lost all air immediately and the cut in the tire is very near to the sidewall and is about an inch long!
Had to get the bike towed home, so unfortunately cant ride until I take the wheel off and get the tire replaced.
Gentlemanjim
May 21, 2011 02:01 AM
shraz
Jun 24, 2008 08:36 AM
HELLA
Jun 26, 2007 12:19 AM
schultzy
Jun 7, 2007 08:10 PM
rangerbrown
Apr 9, 2006 04:02 AM
