help me overheating
Old May 24, 2008 | 11:28 AM
stinkonia600's Avatar
Default help me overheating
my fan does not turn on my thermostate doesnt seem to open and my bike runs hot is the fan not turning on beacuse the thermostat doesnt open so the coolant is not getting hot or what should i check
Old May 24, 2008 | 11:51 AM
kup125's Avatar
Default RE: help me overheating
224-228 is when the fan kicks on. are you hotter than that?
Old May 24, 2008 | 01:43 PM
way hotter 240-250
Old May 24, 2008 | 02:00 PM
fishfryer527's Avatar
220 here.
Hoses, sensor, thermostat. But if the coolant isn't recirculating, maybe the pump is screwed up, maybe the radiator is plugged with impellor bits and pieces. How do the hoses feel and look? does the suction side suck closed? I am just guessing so don't take anything apart due to my response because I am a functional retard when it comes to this mechanical stuff.
How many miles on the bike?
Old May 24, 2008 | 07:23 PM
patman's Avatar
Is there enough coolant?
Old May 24, 2008 | 11:50 PM
drtoohotty's Avatar
also check the fan fuse
Old May 25, 2008 | 12:26 AM
axsys's Avatar
check the fan fuse, and if thats good, the temp switch for the fan is on the bottom left side of the radiator. unplug the single wire that goes to it, and then jump that to the wire that is grounded to a bolt right above the switch. if it turns on, then your switch is bad.
Old May 25, 2008 | 08:10 PM
FLYOU's Avatar
anything over 230 isn't normal. fuse, coolent level, hoses, thermostat, pump... in that order.
Old May 26, 2008 | 09:08 AM
ConeyIsland#1's Avatar
hey, after you check out the fan fuse. look if the fan is properly connected. once in a rare while the connector disconnects from the harness.
aan310
Oct 7, 2013 06:34 AM
StriperAngler
Jun 27, 2010 10:15 PM
tommyo4
Jun 9, 2010 05:12 PM
tommyo4
Jun 1, 2010 11:25 AM
98dakota
F2 Tech
Mar 29, 2010 10:10 AM
