Help with Daily Check list?
Old Sep 11, 2006 | 03:30 AM
Knieghtz's Avatar
Default Help with Daily Check list?
I need to some tips on what to check on the bike before each ride, like tire wear, shape of the chain, etc. i just bought my 02 F4I about 3 weeks ago and i did not receive a owners manual. Any help and tips and maybe how to fix the common problems, is greatly appreciated.
Old Sep 11, 2006 | 04:12 AM
SpiritBreaker's Avatar
Default RE: Help with Daily Check list?
I recently just got my bike as well, I too do not have a owners manaul, but i'll be buying one soon.
Im pretty sure its something simple and common.
1. Check tire pressure
2. Check for leaks
3. Check under the bike for any fresh stains (oil, or fluids)
4. Check guage cluster for any warning indicators.
5. Check Clutch/Cable make sure its tight.
6. Check Throttle/Cable make sure it doesn't increase, while at idle.
Do a quick scan for loose objects if any, screws. etc.
If i missed anything, please feel free to add.
Old Sep 11, 2006 | 04:18 AM
Leveltwo's Avatar
tire pressure is #1
that is what keeps you on the road
Old Sep 11, 2006 | 11:48 AM
Blackdog F4i's Avatar
I just check tire pressure, look for any leaks on the ground. Fire the bike, check your lights. Get on, hold the front brake, and rock the bike check for suspension feel and that the brakes hold. Roll it out of the garage and check the rear brake.
Ride conservatively until the tires warm up.
**edit**
I do a detailed inspection when I clean the chain (every 300mi)
and when I change oil (every 3000mi)
If you have a clip-on master link check it EVERY TIME YOU RIDE. Then change it to a rivet on the next time you replace the chain. Your bike and limbs will thank you.
Old Sep 12, 2006 | 11:42 AM
vasta101's Avatar
Here are some links from the Motorcycle Safety Foundation... The second link is an actuall checklist you can print out....
T-CLOCS
Pre-ride checklist
HERC
Oct 1, 2009 09:48 PM
barky
Apr 17, 2008 11:32 PM
ThomAss
Dec 29, 2006 04:27 PM
graveheart_82
Mar 13, 2006 08:21 PM
Melantus
Nov 14, 2005 04:36 PM
