Headlight problem
Old Apr 18, 2008 | 09:23 PM
Funnyguy's Avatar
Default Headlight problem
Hi guys
I just take my bike out of storage today, after a few cranks it fires up without any problems so i rev it up and "pffff" the headlight just went out like that...I turn it off and turn it back on, the bike starts easy but still no headllights, I checked the 10A fuse, it's still good.. check the connections they're fine.....Has anyone ever had this problem? Please help..
Old Apr 18, 2008 | 09:33 PM
dementedf3's Avatar
Default RE: Headlight problem
could just be a coincidense (sp) Or could have been a spike in voltage. A good sign of a bad Regulator is poping headlights as they are the most sensitve to voltage
Old Apr 18, 2008 | 11:06 PM
honda502's Avatar
Sounds like it just blew the bulb.Check charging system though.
Old Apr 18, 2008 | 11:37 PM
simmadown's Avatar
Check the bulb. If it isnt blown grab a multimeter and see where the voltage is going, check multiple points in the lighting system to the ground ( negative terminal/ frame ) and see where your voltage/ current is interrupted.
Old Apr 19, 2008 | 08:11 AM
Funnyguy's Avatar
thanks guys
I check the lightbulb they're fine.. I downloaded the manual and look at headlight section.. there is a socket for the bulb but i dont have it on mine...could that be a problem? Can any of you guys try to insert the plug right in to the bulb without using the socket and see if they come on? thanks
Old Apr 19, 2008 | 08:55 AM
RojerLockless's Avatar
if you reved it up really hard you deserve it =p
if not then it's just bad luck but sounds like you just gave the bulb too much power after sitting.
cajun rider
Mar 22, 2012 07:37 PM
rnora1
Jun 11, 2009 10:28 PM
bottlebaby
Jun 4, 2009 09:38 PM
josemiguel
Oct 20, 2007 09:06 PM
