Headlight Modulator
Old 03-01-2006, 12:22 AM
tbone_600cc's Avatar
Default Headlight Modulator
I have been thinking about getting a headlight modulator, like this one http://www.customdynamics.com/signal..._modulator.htm. Will this work on bikes with a seperate low and high beam bulb?
Old 03-01-2006, 06:25 AM
DThompson's Avatar
Default RE: Headlight Modulator
I think it will but dont take my word for it,
Daniel Thompson
Old 09-19-2006, 02:17 AM
I have one attached to my high beam. Uses a light sensor to deactivate at dusk. Works great! Definitely a huge change in the drivers at intersections and drive ways. Very irritating....can't miss it.
Old 09-19-2006, 04:42 PM
Yes, it will work. I have been thinking about getting one for my F4i.
Old 10-02-2006, 04:21 PM
amnesia's Avatar
I bought a Kisan "s" version (with extended cable). It works great and I wouldn't ride without it!
The f4i is a bit tight on the installation which is why the "s" version is useful.
I got a P115W-S-DHL. This unit allows both the high and low beam to modulate. The regular unit only modulates the high beam. I'm not sure if the modulation on the low beam is necessary (it's not very noticable) and the P115W-S is probably fine. Either way call Andy at Kisan and he'll make sure you get what you want.
Also, if you're getting either model, make sure it has the NEW software (8 stage adjustable cut-off)
My only hope is that no-one else gets a modulator, so mine will continue to stand out!!!!!!!
I'm interested in their tire pressure monitor.
Good Luck
Amnesia
Old 10-04-2006, 12:39 AM
What I would like to see is a module which flashes the high beams on and off successively every half second, like what I do all the time to make people aware I'm back there coming forward... this of course would be just a button I could hold down and it flickers the light for me, instead of whapping my thumb up and down.
I think the brake strobe is a good idea, but I've seen some that I'd be embarrassed to have... but on a bike it seems a bit more useful...
WV_Rider
04-03-2011 09:45 AM
kgarrison4420
04-23-2010 11:12 PM
chetman7
03-20-2010 10:22 PM
MrModest501
09-30-2008 07:26 PM
jjkukla
Official Vendor For Sale & Group Buys
05-18-2007 02:49 PM
Quick Reply: Headlight Modulator
